R53 EMU Black - Coil on plug conversion
Hi all,
I’m looking to use the drop in R53 EMU black in my vehicle which will be converted to separate coil on plug, however looking through the pin out, it appears there is only two ignition coil outputs available. The only other additional output that appear may be suitable is the injector 5,6 driver in one of the extension plugs.
Is it possible to re-purpose any of the additional outputs to drive additional ignition coils with this ECU?
Cheers
I have an Ecumaster Pnp on my Mini. What’s been said to me it that Coil on Plugs don’t work with the PnP ecu.
I’m trying to find a solution because the oem coilpack doesn’t let me raise the boost after 1.9bar (start to misfire at high revs). My tuner already increased the dwell time to the max acceptable on the oem coil pack.
If someone can help, i will be appreciate.
*Im running a high hp R53 Turbo, not supercharger.
Thank You,
André Silva
The same thing happened to me. I bought 4 R8 coils and was going to use the same lost spark configuration but it wasn’t possible. Please provide a solution. I’m also using a turbo.
Same here on input from anyone? I used to run sequencial ignition on my old setup with one of the first emu the ultratech ecu but the black pnp has no ignition outputs 3 and 4, although on the software they seem free of use but no outputs on the pigtails??
