Mux switch help
I’ve been trying to get the mux switch to work for my cruise control and I cant get it to work at all on my 1.8t PnP ECU. I wired it exactly as the drawing in the help menu shows. The only variables at this point are: Are my input/mux switch parameters setup correctly, and what should they be? Also i must have the wires connected into the incorrect terminals on the ECU. I attached a diagram describing what pins on the back of the ECU I used.
I’ve cycled through the 4k7 pullup/pulldown and 1m pulldown options with no change. I just always see 5v on analog in 6 and mux switch raw voltage of 1.84v.
The instructions say to use sensor ground, but I’m not clear on what that actually means sinse every descriptor just says “analog ground”, so maybe this is where the discrepancy lies. Also attached the BAM pinout that I’m using for reference.
BAM pinout spreadsheet v2.pdf (28.9 KB)
