New EA888 Gen 3 base map v2.1
EA888 Gen 3 base map v2.1 – now available directly from EMU PRO software
We’ve published an updated EA888 Gen 3 CJX base map (v2.1), now available directly through the Base Map Loader – no need to download it manually from the website.
What’s new:
  • Added port injection control
  • Added thermostat and fan control
  • Added cruise control
  • Added oil pressure control strategy
  • Added Push-button Start/Stop support
  • Added TOLS oil temperature/level sensor
  • Improved DSG behavior
  • Improved VVT settings
  • Improved high-pressure fuel pump control
  • Improved injection angle control
  • Improved A/C operation
Multiple vehicle variants supported
The base map package covers several EA888 Gen 3 CJX configurations:
  • Direct injection only / Direct + Port injection
  • Key ignition / Push-button Start/Stop
Select the variant that matches your setup when loading the base map.
Requirements:
Downloading base maps from the internet requires New EMU PRO software version 261.1 beta
How to use it:
Open File / Load Base Map…, click “Update,” and select the EA888 Gen 3 CJX v2.1 base map to download it directly. For full step-by-step instructions, see the How-to Load Base Maps in EMU PRO.pdf
As always, treat base maps as a starting point — careful tuning is still required, and you must verify all assigned inputs/outputs match your wiring before loading the map to your ECU.
Sincerely,
The Ecumaster Team
