New EMU PRO software version 261.1 beta
New EMU PRO software version 261.1-beta is now available.
What’s new:
  • Base Map Loader (File / Load Base Map…) can now download base maps from the web (a new base map for EA888 will soon be published through this channel)
  • Project Comment – added a new panel and a Tools / Set Project Comment… dialog, both allowing you to view and edit a saved comment (up to 200 bytes)
  • Engine Kill functionality added – available via Devices / Kill Engine menu command or the Shift+Ctrl+K shortcut
  • DBW Target now has separate Max rate tables for opening and closing
  • Added extra Idle Air flow Correction tables for Coolant fans and Air conditioning activation
  • TOLS sensor added for Oil level / Oil temperature
  • Added axis labels to 3D table view
For more details and full list of changes, see the changelog.
Download the latest software update and explore these new features: http://www.ecumaster.com/testVersions.html
We appreciate your feedback — it helps us make EMU PRO even better.
Sincerely,
The Ecumaster Team
Thank you for adding the engine kill feature!!!
The VE-Tuner in 261.1 shows in the suggested VE Table wrong huge negative values.
Filtered for Load min 30 (correct values)
Filtered for load min 40:
Suggested VE values are -214,748,368.0
Thank you for spotting this issue.
Unfortunately, we are not able to reproduce it. Could you please share a datalog that demonstrates the problem?
You can send me a DM or share a link here.
I saw in this version it fixed the AC recovery delay issue, but now with recovery delay configured it doesn’t actually implement any sort of delay.
Could you share the log and project? I cannot reproduce such a problem.
Could you please give us any additional feedback regarding the AC recovery delay not working?
We have a release candidate of the software almost ready and would like to release it tomorrow.
New software update 261.2-rc1 is available. It fixes VE Tuner issue raported in this thread by @Slash200
