Clearing DTC works perfect for my setup now.
Previously I had to fire up OBD tools to clear 0001/0002 DSG communication errors after every offline project update which was quite annoying.
Are there plans to enable single side (return spring) thermostat control? (or second closed loop DC strategy to achieve the same)
Might be related to the import/export changes in this version
I noticed that scaling, colors, filtering etc of custom channels (calculated or received via CAN) are not saved in desktops. See the screenshot of one of my pages.
Also is there a way to enable live filtering for custom channels?
e.g. I’m importing current (amp) channels from my PDM (non-ecumaster) and they’re quite noisy. There is no such option on the PDM side unfortunately. I’m checking plausibility of power consumption of critical devices and It’s something I’d love to have on my dashboard Live not only in logs afterwards.
Updated to play around today, noticed a new menu under trigger called ‘fast cut.’ Searched the changelog but could not see anything about this and the help doesn’t have anything. Any quick explanation for what this is?
This “Trigger / Fast cut” setting is NOT functional. It was used during development and will be removed in the next version. Thank you for letting us know.
In this firmware update we have implemented a second mode for spark/fuel cut called “Automatic” (internally referred to as “Fast cut” during development). This new mode is easier to configure, as there is no need to tune a cut percent table as before.
It has been implemented for 4 strategies (from the changelog):
Yes it does work as intended with my single-side actuator.
The default actuator PID works quite well as is and I only need to brush up the base positions and temperature PI at all power outputs. Thanks
