New EMU PRO software version 261.2 release candidate
New EMU PRO software version 261.2-RC1 is now available.
This update adds a couple of small client features and fixes several minor issues.
New features:
  • Added menu command: Devices / Disconnect
  • Added a “Save DBC File…” button to the Project Tree / CANbus Transmit Frame
Fixes:
  • Fixed EMU PRO-8 compatibility with EGTtoCAN – all 8 channels now work correctly
  • Fixed a rare bug causing VE Tuner to show large negative numbers in the Proposed VE table
  • Fixed an issue where the Vehicle / Speed Limiter / Activation Custom Channel was not working correctly
  • Fixed a bug that prevented saving a password-protected project in offline mode (issue introduced in version 261.0)
  • Fixed an issue where the frequency of the “Engine Cylinders cut” channel was not loaded from a project file
Download the latest software update: https://www.ecumaster.com/testVersions.html
This is a release candidate — if no major issues are found, it will be promoted to a public release. We’d appreciate it if you could give it a try and let us know if you run into anything.
Sincerely,
The Ecumaster Team
Hello
After Install I lose the complete Menue at Idel under Airflow Enable
Greetings Frank
Thank you for testing the software.
I was able to reproduce the issue. The menu under Airflow Enable disappears completely.
For now, the workaround is to refresh the UI using the Shift+Ctrl+B keyboard shortcut (menu Devices/Reconnect).
We will do our best to release an update tomorrow.
We released software update 261.2.1 release candidate (RC2), which fixes the bug reported by Frank @FHMotorsport.
Thank you, guys, for testing this version!
