New GDI Driver firmware 3.5 is now available.
This update also requires updating the Light Client to version 2.4.
What’s new:
- Expanded diagnostic information
(Changes to the CAN stream – channels or logic based on the stream might need reviewing) - Added low-side output mode for pump control
(Requires external flyback diode. Check the manual for wiring example) - Parameter Inj duration max renamed to On time max
(When loading an older project file after the update, this parameter will not be imported) - Fixed a bug that caused Inj duration max/On time max to be shorter than set by the user
- Added time limits for pump control (On time max, Period min)
For the full list of changes, see the changelog.
Download Light Client software version 2.4 today! https://www.ecumaster.com/products/light-client/
To update the GDI Driver, connect to the device and select:
Upgrade → Download from ECUMASTER .com server
Sincerely,
The Ecumaster Team
