New software 3.034 is available!
Link to the software:
https://www.ecumaster.com/files/EMU_BLACK_V3/EMUBlackV3Setup_3_034.exe
EDL firmware
If you experience communication issues with the device, please restart your computer. We have noticed that these problems are caused by the Windows USB driver. We are working on reproducing and resolving this issue.
Uploading a project from software version 3.034 to earlier versions may cause changes in the User Defined CAN settings. In such cases, these settings need to be reviewed and manually corrected.
Change log:
USER CAN: Logging channels with id > 512 are sent correctly
USER CAN: Data channels with bit width 9 to 15 are sent correctly
USER CAN: User-defined timeout for Rx messages added. If the time out occurs the default values are used.
USER CAN: Offset for TX output added after multiplier/divider. Output value = Log channel value * Multiplier / Divider + Offset
CAN: Fiat 500 / Grande Punto. Clutch pedal status sent to CAN. Cruise control lamp was added.
CAN: Fiat 500 / Grande Punto. CAN switches remapped: AC request - CAN SW14, , Hand brake - CAN SW15, CRANK REQUEST - CAN SW16
CAN: Grande Punto. Cruise control buttons added: Cruise control on - CAN SW17, Cruise control resume - CAN SW18, Cruise control speed up - CAN SW19, Cruise control speed down CAN SW20. Drive style - CAN SW13, Brake switch from BCM, CAN SW 12
CAN: FIAT 500 EURO 6 / US version: Brake switch from BCM, CAN SW 12
CAN: Fiat 500 - EURO 6 now is a subversion of EURO 5
CAN: Fiat 500 - Drive style added to Rotary switch CAN 4. Please see CAN setup help for details.
IDLE: Minimal MAP to activate Idle (Idle On if MAP over)
TC: Separate rotary switch for User torque reduction correction.
ALS: Tables Cylinder cut and Ignition correction X axis can be TPS or PPS
COOOLANT FAN: During “Time to engage” phase the temperature hysteresis wasn’t used
LOG: Lambda 1 and 2 gauges are added
HELP: Traction control
HELP: Rev limiters
HELP: User CAN
HELP: Autoutne
Here is a firmware with fixed Idle activation only if MAP over defined pressure (worked opposite in official release).
https://www.ecumaster.com/files/EMU_BLACK_V3/emuBlack_3_034_idle_MAP_fix.zip
Is this wbo calibration value in reasonable region please?
if you make the calibration with the sensor disconnected then yes.
Yes I did…
Can I ask you to increase idle ignition target to 30deg? Im allready working on big cam 1.6 peugeot engine and it like much more 30 deg 2000rpm idle like 20deg
also max torq ignition advance could be till 35deg
no poroblem. It will be changed in next version
I just would like to remind the issue that was answered in 3.032 release.
Is it possible implement the Idle activation by the function?
Thanks a lot.
It is on the to do list. I hope it will be implemented in the next version
Can the Evo X canbus stream be updated on the V3
emuBlack_2_169_EVOX_CLT_DASH.zip (196.9 KB)
for the CLT display offset on the center dash? It reads high temp on the Evo X center CAN display when temp is normal. Attached is the firmware update fix you sent for V2 software.
So I have prepared a V3 file for my emu black. For the moment, its running a V2 software.
What is the susggested procedure to upload a V3 software into the black?
Thank you
Just connect with V3 client and it will ask you for the upgrade.
Hello, how did you do with the alternator signal?
