OBD2 Connection issues
Hey all,
I’m having some issues with my OBD2 Port, I am not getting any information through it.
As for the EMU Black, the option for OBD2 support is checked, also the Bus Speed is set on 500kbps and the 120ohm terminator is enabled.
As far as my wiring goes, the emu is connected to the standard wiring of the E46 M3. The other difference is that the instrument cluster has been replaced with an AiM MXG (second terminator option enabled here) and that the abs is on a separate stream connected to the aim as its not an e46 unit.
In normal operation the CAN stream works without any issue. I can see everything the EMU Broadcasts on the AiM Dash and the EMU also receives input from the Lambda2 Can. So connections are there, for some reason its just the obd2 port that doesn’t work (wiring seems not possible as its still the standard e46 wiring there).
Any ideas on what the cause could be?
