Pectel MQ12 canx file
planning on using Adu5-as and pmu16-as with pectel MQ12. Its mandatory to log can messages from MQ12 regarding the active diff behavior
Car is equipped with wrc transmission and electronically controlled by mq12.
I already found sq6 canx file, is there any chance to have support for mq12?
The only thing you need is the description of CAN data from Pectel.
If you have it, you can create your own CAN inputs. If you are not familiar with CAN, upload the description, and we can create the CANX file for you.
another issue would be with the client desired can keypad, HP ELECTRONIK HP9642.
for this device i already have the supplied can description only need to proper import the to adu and pmu
HP9642-TechnicalManual.pdf (37.3 KB)
