Peugeot 206 rc can bus Emublack
Hello from Greece working on Peugeot 206 rc and trying to connect can bus to dashboard and not working anyone familiar with Pegeuot 206 arc dashboard?
Thanks in advance
Hi Tasos, as you know, models like 206 RC, GTI use BSI brain, the normal can data line may not respond to the emu black that you define as high and low. As a solution, I solved it by removing the cable from the can brain from the original BSI can H and Can L outputs and then wiring the Can H and L terminals on the emu. You can find the outputs according to the BSI code from the autodata program and connect them directly to the emu.
Hello,thank you very much i will make a try :slight_smile:
CAN H line is B3h ecu plug B
CAN L line is B4h ecu plug B
One is yellow one is white-ish and if you pull the sheath they are twisted 5cm further down.
250kbps data rate
