PMU 121.0 DBC Export Menu Issue
Hi
From the PMU Tools menu, it appears the the “Export selected…as .DBC…” option does not work (see highlight below). I am able to export a .canx file, but not a .dbc file, through the Tools menu. When trying as a DBC, the PMU client returns an error to select one or more CANBUS messages. Or is this expected behavior and I am missing something?
The client successfully exports to DBC when selected from the CANBUS message export configuration screen (the button to export as DBC).
You can export in that way only CANbus Message Objects, not CANbus Exports. To save CANbus Exports as DBC - you have to click the dedicated button “Save .DBC File” in the CANbus Export window - just as you wrote.
Ah, understood. Thanks for clarifying!
