Pmu16as dbc file
is there a way to covert or export the pmu can profiles into a dbc file? i can find a way to export into a canx file but not a dbc, or does anyone have a dbc file for a pmu16as?
attached below, you can find the PMU16-AS DBC file.
PMU-16AS_#1.dbc (8.3 KB)
awesome thank you, that saves a ton of data impute.
Do you happen to have the .dbc for PMU-16AS_#2_ID670 as well? It would be very helpful.
#1 file with changed channel and frame names to make it easier to distinguish pmu#1 and pmu#2
PMU-16AS_#1.dbc (8.9 KB)
PMU-16AS_#2_ID670.dbc (8.9 KB)
Thank you! Much appreciated. I have been doing a lot of back and forth work on the CAN communications on this current project. I am using an M190 ecu and L180 logger with two PUM-16AS, CAN switchboard, ADU5 and gearDisplay. I saw rumors that .dbc to .canx conversion may be coming out in the newer software. That would be a huge addition or the to create custom devices in Lightclient and pick from the CAN stream to create custom .dbc or .canx configurations. But it is nice that you are able to help provide these files.
The new PMU Client version has been released. You can now export CANBus MOBs to DBC, so you can also make a CANX to DBC conversion this way.
