Hello. I have bought pnp adaptor for my mx5 nb and an emu black. The car is stock. When I plug it and I load the base map everything is ok except I don’t get power to fuel pump. Is it possible the pnp to have problem or I miss something inside the software? I checked the aux 2 that is used for fuel pump but I can’t trigger it. The car works perfect with the oem ecu. I just noticed after a lot of search that a pin is wrong on the adaptor. It says that 3n from the cars loom goes to g13 for the fuel pump but actually the 3p on the original ecu is fuel pump relay! Any help I am lost
Did you try and swap over from 3N to 3P and see if it worked?
Hey mike, yes i put 3p to 3n but i dont know what 3n is so i left it out!
NB uses either one of those so I guess just connect it to one, if it doesn’t work, try the other
i fixed connecting the 3n to 3p and i left out the original 3p until i find out what it is! thank you for your help!!
It’s relatively simple, some NB’s use 3P, some use 3N, doesn’t matter if you leave them interconnected.
