Audi s4 2.7t pnp wiring question
Why is the pnp for audi 2.7T wired like this and not like that the injectors and coils would match the numbers from 1-6?
Im getting rid of the pnp adapter and wiring it directly to emu black and I was wondering why not to change it to be 1-1 2-2 3-3 4-4 5-5 6-6
Thanks!
No idea honestly. However since you have access to the EMU black pinout, you can certainly wire it how you choose. I would be careful though in using the ECU master’s supplies base map for the car as the wiring will most likely differ from their map.
Yes, I know that and I have to reconfigure the settings, I have been running the car for a while now but I had some problems with the pnp adapter so I’m removing it.
The base file configuration also needed some working before it worked with this wiring.
Was just wondering if there was any practical reason for the wiring before a change it.
Gotcha. Nah, other than just being confusing haha. Glad to see it’s working for you.
