Primera p10 + SR20VE + DET3
Hi, I installed an SR20VE engine in a Priemra P10 and I’m using the DET3 to start and manage the engine, but I can’t activate the VVL solenoids. I’m feeding the solenoids with 12V after the key, the same connector that powers the DET3, and the negative voltage is managed by the parametric option. I’ve set RPM > 5000, and it’s true that when it reaches 5000, it does something strange. The engine is running poorly. But I don’t see any problems with the mixture on the AFR clock. I don’t hear any more valve sounds, only that when I activate it, it runs poorly.
Has anyone managed to activate the VVL solenoids, even if it’s through another method?
Im curiuos, have a RB20 on a DET3 and im not able to get the ignition setup correctly, to have an accurate rpm reading. Which trigger setting are you using?
