Problem with coolantfanstate
Hey, having a problem that happend this weekend that the ecumaster black wont send canbus signal from coolantfan outputs to start my outputs on the pmu16. Have been working for years before and fan works if try it from the Pmu, but wont get value change from emu black if i invert the signal. Have tried my fuelpump tigger and that work and its via canbus also. What coult be wrong? Software or the emu black?
Function invert working only on hardware output not over can bus.
What did you change?
Does the PMU receice the rest of the EMU Black data?
It works on my fuelpump that also is canbus signal to start😅
I havent changed anything about the fan setup, but did change it so the Pmu goes by rpm and clt instead of that coolantfan output signal
