Radio button and group where only one button at a time is active
In the EMU Pro software guide there is following explanation for the button type:
◦ radiobutton group - button to open a group of radio buttons
◦ radiobutton - further buttons in the radio button group
USECASE: I need to configure DSG gear selector based on the keypad input where only one of the buttos is active at the same moment of time.
Do I understand corectly from the above that for P button I select the type as radiobutton group and for the rest RNDS I should select the button type as radiobutton ?
If not, how it should be configured ??
Question 2:
Is there a posibiity to have more than 1 radio button group within one keypad ??
That’s correct.
With that setup, only one of those buttons can be active at a time.
Yes.
Radiobutton group starts a group
Every radiobutton after that is assigned to that group.
Another Radiobutton group will start a new group.
Buttons for the radio group are checked in sequence, starting from the top left and proceeding from left to right, row by row.
Thank you very much for clarifying that!
