RB25 DET , vct, tps and cas connections?
wiring up emu black to a RB25DET .
several things i need to know :
do i use the connector on the actual tps ? or do i use the other connector thats joined up to the tps via the short lengths of wire ? what terminals on the tps goto what on the emu black ?
with the VCT , there are two wires , one is earth, the other is +12vdc where do they connect up on the emu black ?
the CAS has 4 terminals, 120 degree , 1 degree, power and ground, where do these connect up to the emu black.
thanks.
TPS should be connected to the piece of wire that is hanging off the TPS, not the one the is directly mounted. You will need to find a wiring diagram for the engine you have and then just wire the things accordingly to match the EMU pinout. This would mean the TPS, VTC and CAS.
Π§ΡƒΠ²Π°ΠΊ, Π² ΠΈΠ½Ρ‚Π΅Ρ€Π½Π΅Ρ‚Π΅ ΠΏΠΎΠ»Π½ΠΎ схСм ΠΈ ΠΈΠ½Ρ„ΠΎΡ€ΠΌΠ°Ρ†ΠΈΠΈ, Ρ‚Π΅Π±Π΅ Π½ΡƒΠΆΠ½ΠΎ лишь Π²Π½ΠΈΠΊΠ½ΡƒΡ‚ΡŒ. А с Ρ‚Π°ΠΊΠΈΠΌ ΡƒΡ€ΠΎΠ²Π½Π΅ΠΌ ΠΏΠΎΠ·Π½Π°Π½ΠΈΠΉ ΠΊΠ°ΠΊ Ρƒ тСбя сСйчас, Ρ‚Ρ‹ Ρ€ΠΈΡΠΊΡƒΠ΅ΡˆΡŒ Ρ‡Ρ‚ΠΎ-Π½ΠΈΠ±ΡƒΠ΄ΡŒ ΡΠ»ΠΎΠΌΠ°Ρ‚ΡŒ
