Renault Clio 172 problems
Iám new here and have a problem.
I’ve been installing Emu Black in a Renault Clio 172 for a week, no time-consuming work thanks to the adapter cable. The basemap is a good basis, the engine runs well and cleanly.
There are 2 problems, when the ignition key is turned slowly the starter does not respond .
Turned quickly, the starter works and the engine runs.
In the cockpit, the SERV and ESP warning lights light up permanently.
If I connect the original ECU unit , the engine starts even when the ignition key is turned slowly.
The warning lights go out for 1 second. after switching on the ignition…
Anyone an idea??
Best Regards
Stefan
starter motors is controlled by multifunction module not by ecu but from what you are saying possible that is can bus errors make sure correct can bus is selected .
Hi Greg
Can Bus ,good I take a look what sort of Baudrate use in this car and check it .
Thank you
Stefan
Hi
Can you send me please your base map i need it for a swap f4r
Thank so much
Hi ,
No probleme,here you go .the map is for 480 cc Injectors,
You need also the newest firmware on your Emu Black…
all the best
Stefan
(attachments)
Base_Supercharger_ 480cc_Ver2138.emub (146 KB)
Maybe a better version …try it
(attachments)
final.emub (147 KB)
tanks you very much i will try it
The EMU doesn’t output the CAN data (Maybe K-line?) for the UCH/immobiliser so I always just bypass the starter relay, its only used as a starter inhibitor, not as a true relay.
Hi there, I’ve downloaded this map but can’t import it to a project, any ideas how to go about this? Thanks
