Rotary engine timing lock (leading/trailing)
Is it possible to implement a timing lock for rotary engines with leading and trailing coils?
To do the base timing adjustment, on a rotary engine (example values for a 13b-rew) the timing lock needs to be set to leading -5° BTDC and trailing -20° BTDC.
regards
Bastian
With the current firmware, you can lock the leading spark. Modify your ‘Ignition Trailing spark Delay’ table to -15° ADV to achieve -5° BTDC for the leading and -20° BTDC for the trailing spark.
