Try it, maybe if you use the middle value for each segment, it should be enough. You can have almost 20 values in an axis. Recreate it or modify the axis, to have more columns.
Thanks again. I did try to, but it can’t seem to get more than 6 for the voltage range.
I’ll try using the middle value as you suggest and see if it works.
