How are you guys wiring all your sensor 12 volts, are tying them into the ecu main relay or its own relay I’m looking to run
Cam and crank Hall effect
Wideband 4.9
Can hub for dash display and egt to can
And maybe a boost solenoid
Do you guys think that too much on therelay powering the ecu or should I leave the ecu on its own relay
Thanks in advance
