Software opinions
In 3.025 Mux Switch issue still occurs.
It would very useful to add a reset function to default state of Latching switch, for example keeping it pressed for 3000ms.
Synchronization time is brilliant in V3, not any shame in front of customer:-)
Autocalibration of DBW came across few times of forcing too much to closing direction resulting in stuck position(thus informing about it). With finger help gone back and finished the process.
It is possible to add reset functionality to latching switch.
According dbw, it can be cqused by throttle wear.
For the BMW owners (and other that want PWM fuel pump driver) it would be nice if you could add CAN stream support for the EKPM2/3 PWM driver (like in the Maxxecu). I have it working with user defined CAN stream, but would be nice if it was available in the drop down menu.
If crankshaft&cam sensors were moved to Sensors and inputs in V3, it would logical to move there a Knock sensor configuration:-) But in my opinion; Knock, Crank & Cam sensors parameters were in perfect location in V2, without splitting into type of sensor and trigger configuration:-)
Afterstart idle control with V2 was much easier, it’s a bit of struggle with V3 not having an idle bump down just a second after bump up during cold vs hot start. Tables seems to be similar, besides Parameters(which are split now in different groups).
Is there a way to invert H-bridge outputs? If not, would be nice to have that option.
Afterstart idle control is here:
Please always assume the strategy in V3 is better and more flexible than in V2 :slight_smile:
According digital inputs configuration, probably there will be virtual links to Digital input configuration in the trigger setup.
What do you exactly mean ?
If you use them as separate outputs all strategies has invert output option.
If you use it as DBW you can invert motor direction.
What is your case ?
If you send me can definition from user CAN I will implement it under Fuel pump control
Could you attach your base map ? Spark cut for idle can work only when it is selected and ECU is in idle state.
It will not be a problem to add notes what will be saved inside file.
What do you mean issue occurs ? And what issue ?
I add 3rd column, not a problem.
The names are limited to 16 characters due to limited memory resources.
12 functions is 50% more than in V2 (8 functions). Also in V3 functions are more capable.
The 12 functions is a kind of compromise because of the memory limitations.
At this moment add more functions is possible but quite demanding.
You can try to combine some functions into one as you can use many operators inside one function.
Blockquote[quote=“Jadzwin_ECUMASTER, post:151, topic:604, full:true”]
What is your case ?
[/quote]
I have 2 DC operated vacuum valves to change the operation of resonance chamber and lenght of intake runners.
These are controlled by load/RPM/TPS (built functiins for that, earlier parametric outputs).
Valve has +12V from a fuse when IGN on, by default HB1A and HB2A seems to be connected to GND. How to invert that?
How I can use 1A/1B/2A/2B as separate (independent outputs)? I thought A and B is always opposite…
Outputs are HBRIDGE1 A, HBRIDGE1 B, HBRDGE2 A, HBRIDGE2 B
If you use functions you need to control each output with the seprate function, and create apropriate logic
Forgive my ignorance, but where I can check/set default state of these H-Bridge outputs?
If I understand correctly the action sets the output to “the other” state (i.e. from GND to +12V).
Is there a way to “pin” certain H-Bridge output to a certain “default” state (i.e. floating / GND / +12V) and that “pinned” state would be then the initial state for the function change… ?
If you assign hbridge output to the function its state will be always equal to function states.
Functions are evaluated continuously where fn1 is evaluated first, fn2 next and so on (it can be sometimes important when you use function in function).
So if you want 2nd output to be always inverse of 1st output, just assign function 1 to HBRADGE1 A, and in Fn 2 invert its state.
For example:
So if fn1 will be 0 (GND) the fn2 will be1 (+12V).
Thank you. I got the point, but this requires to use 2 Functions and 2 Outputs (maybe a “virtual” one) for sake of function calculations? Do we have such virtual ones available anyway?.
Having a negation of the output in the same (first and only) function (simple NOT for the output to “mark” in a 5x5mm square field or so by aka “invert”) would save one Fn and one Output.
Sure I can build the function “the other way round” so it will be active when those criteria would be not met, but it would be so much more user friendly just to invert that with a simple click of a mouse and selecting “invert result” :slight_smile:
You dont need virtual functions. You have two outputs and two functions.
Fn1 - Hbride1 A - make calculations you need.
Fn2 - Hbride1 B - Is false (Fn1)
Each function without assigned output is virtual. In next version in dropdown list there will be Virtual instead of None
That’s correct, Fn without output is my “virtual” output, but eats one of the Fns that are available in total. Smn already hit the limit of the Fn number IIRC.
