New software 3.020 is available!
The lambda sensor circuit needs to be recalibrated or the default calibration value will be used.
https://www.ecumaster.com/files/EMU_BLACK_V3/EMUBlackV3Setup_3_020b.exe
Change log:
- EMU CAN stream DBW and DBW target pos are send properly
- Quick tune panel - now grid size can be defined from 3x3 to 5x5
- Flickers problem with graph log window when shrink fixed
- TFI trigger support modified and bench tested.
- CAM based trigger with missing tooth added and bench tested
- Scope now can take skipped edges form triggers that are decoded to multitooth like (Porsche 132 ,Subaru 36-2-2, etc.)
- Boost:
- fixed boost target from table channel,
- boost target limits fixed
- Custom ignition corrections - Y axes didn’t work correctly
- Fixed issue with axes bins display “modified”
- Fixed issue with custom names saving to eeprom
- WBO calibration constant moved into other part of eeprom. Recalibration required!
- Knock sensing is disabled during cranking
- User names are displayed properly in user function windows
- CAN analog inputs axes voltage range fixed (0-5V)
- Rev limiter target CAN BUS channel added to control rev limiter target over CAN BUS
- Triggers improvements during the exgine startup phase
The following triggers are already working:
- 1 missing tooth
- 2 missing teeth
- multitooth
- Nissan trigger
- 1 additional tooth
- rover18-1-18-1
- TFI
- CAM toothed wheel with the missing tooth
- CAM toothed wheel with the additional tooth
- Porsche 132
- Porsche 129
Yamaha 24-1 removed , min tooth = max tooth = 15
Seadoo 36-2 removed, min tooth 26, max tooth 30
