Stuck with some troubles and questions:
- When I press clutch pedal (it’s connected to switch 3 by ground), AC turns off shortly.
In log its looks like shortly switching of switch 1 (where is the AC IN is connected).
Firstly I stuck with problem that Switch 2 was connected with Brake pedal by Power (12v as stock wire for Toyota did) and it turns off 1&3 that is connected by ground. I did inverion for the switch 2 by relay. This problem gone.
But this problem I dont see any parametr for this. Is it a bug or an interesting thing with connection? The wire of clutch switch goes from ECU Ground through pedal stock oem “button” at pedal and goes around to ecu to switch 3 input.
Is there any opportunity to choose filter from CAN analog inputs from CAN Switch board v3, i connected there a some pressure&temperature sensors and its a little bit oscillate - want to filter it just for comfort.
I use onboard UEGO and have a habbit to look at AFR, and when its full lean - it shows 7.2 AFR.
Does Ignition Correction curve (by Ign Angle) work by 0,5 angle? Or it only shows it by 0,5? And for the main ignition advance the same question (I’m not sure that there is important to work by 0,1 for exam
200826_2105.emub3 (69.2 KB)
20260820_2203.emublog3 (128.1 KB)
ple, but still interesting)
Why if I want to turn off only the PID or overdrive a Idle Airflow it stops even a ignition correction by curve? Is there an opportunity to be cofident that my correction is work properly without any help from other systems?
May be it would be good to ignore AC Press parameters to stop work AC system if AC press status is unassigned - I get it out that it is a problem, but…
In future is there any plans to upgrade the log viewer inside V3 studio? In would be good with oppotunity to delete before or after chosed moment, may be search of parametrs (like a list of parameters and for any of it it would be great to choose search greater than or less than). Sometimes its diffcult to search something in 1-2 hours log file.
Log, project and the picture pinned.
Big thanks!
Toyota Soarer JZZ30 98, 2jz-gte vvti, EMU Black REV F, CPU REV G.
