Support for Hella 6PP 010 378-201 / BMW 1261861333
Are the following sensors supported or planned to be supported seems like a cheap solution for multi temp / pressure sensor and only potentially uses one input
Hella 6PP 010 378-201 / BMW 1261861333.
as i have seen it works well with Maxx ecus
Should be doable. We will buy the sensor for tests
Awesome be good to have a cheap solution for sensors :+1:
Could these be used for fuel and coolant also?
240307_2002_KI_Oeldruck_Temperatursensor_OPS_T_FORVIA_HELLA_EN.pdf (429.3 KB)
Hope this helps. Admittedly found it right on Google but I figured it’d be best to drop it here too.
Jon
Any update on these ?
I have these sensors and would like to use as well for coolant temp and pressure as well as oil temp and pressure, and fuel temp and pressure
Still
Would like support for these too be really useful
