Digital sensor support
Any plans to support digital sensors?
  1. SENT support?
  2. Hella oil pressure and temp sensor? Used on some BMW engines like N20. Datasheet here: https://www.hella.com/resources-soe/assets/documents_global/240307_2002_KI_Oeldruck_Temperatursensor_OPS_T_FORVIA_HELLA_EN.pdf
  3. Hello oil temperature and level sensor? Used on some BMW engines like N20. Datasheet here: https://www.hella.com/resources-soe/assets/documents_global/10073181a_AM0.pdf
to partially answer my own question:
#3 (oil temp and oil level) is supported in an experimental version of the software (115.0) so there is hope for #2 too.
  1. Yes, we support four SENT inputs in the ECUMASTER GDI Driver. The SENT data is transferred over CUNbus to EMU PRO at a frequency of 1 kHz.
    We are currently finishing the closed beta testing of the hardware and software.
Could somebody confirm that n20 oil level/temp sensor works with pro8 currently?
p/n 12617501786 12618608779 12617598860 etc
