Tacho input to PMU 24
Hi, I have a MSD ignition 6AL which has a 12v square wave output at 20% DC for the Stack dash tacho. Car is on carbs and coil so no ECU.
What’s the best way to connect RPM to the PMU 24 for logging?
PMU unfortunately doesn’t have a digital input for this.
Does the Stack dash have a CAN connection? You’ll need a device in between the 6AL and PMU to be able to data log rpm.
I have seen this request a few times now and hopefully in the future the PMU gets revised with a digital input or two…
