Trigger setting Yamaha CP3
Hi, I’m doing basic setup on a Yamaha CP3 (MT09,FZ09) engine. It’s a three-cylinder engine. I know it has a 24-2 trigger, I’ve already managed to get a good signal on the scope, but I can’t find the correct setting for the first tooth and the sensor angle. You can’t check anything on the engine without disassembling it. Has anyone done something similar?
did you solve your issue?can you share the scope?
