Trigger Setting Help
Hey guys,
Audi A3 8P VR6 3.2L BUB engine
I assumed I’d be better at figuring out the trigger settings and injector phase based on the new settings being easier. V2 has a secondary trigger setting name “VW R32 4 teeth” which is missing in V3. I took a scope but I guess I’m to novice to make heads or tails of it.
Car runs but runs really rough, like my spark/injector phase is not correct. I’ve tried a couple things but it seems I’m not going in the correct direction.
In any case, I have a scope and file if anyone wants to take a look and point out my stupid, rookie mistakes.
I appreciate the help and all the Effort going into the V3 upgrades.
Micky
Here are the files, work in progress. the Scope file will have to have the TXT dropped off the end, it wouldn’t let me upload the scope format.
20240419_1543.emublog3 (163.0 KB)
shit run after injector.emub3 (57.5 KB)
scope_2024419_1538.emubscp3.txt (635 Bytes)
Now emubscp3 files can be added.
Please find attached bub base map. It is DSG version.
If you want to use dsg calibration please zero the torque losses table.
We experiment with that, it has potential but still looking good settings.
07_03_2024_bub_looses_torque.emub3 (55.6 KB)
This worked great @Jadzwin_ECUMASTER . Thank you.
I realize where I went wrong now… Dumb oversight on my part.
Appreciate all that you do.
