Hi, if you have an adu and emu pro, is there any reason to choose one over the other for usb logging?
If you want to analyze lap times, logs from ADU are better.
If you want logs with all the ECU channels, you want logging in the ECU.
You can always log both if you want all the data.
What about ADU makes lap time logs better?
One of the features of the ADU is lap timing, so it is better to log lap-timing data on the ADU instead of sending it via CAN to the EMU and logging it there.
The main benefit of logging in ADU is that it saves your lap times in the log.
You can also open the log in the ADU software for quick analysis.
EMU PRO can log GPS, making it a viable way to log track data.
However, you must use the DataMaster software for lap timing analysis, which requires a bit more setup.
Hi Marek, i changed now the gps from the gps channels to the can menu setting, but i dont see it in the logs do i have to activate the channels somewere spacial?
