Hey Guys,
As i’m using an external MAP Sensor on my built - i’m wondering if i could use the unused internal MAP Sensor to measure the crank case pressure?
I’ve seen that i can set it as BARO Sensor - but i want to use the crankcase pressure table to calibrate it. Is there a way to do it?
BR
