Baro pressure from MAP before crank
I’m using another ecu that have the option to use set the barometric pressure from the map sensor. Of course this strategy is not ideal for hillclimb, but for most 20-30 minutes race works perfectly fine.
Can we add it as option in the future revision of the pro software?
We latch the map using custom math in the project tree. I know it has been brought up before to add the feature.
Can you share it? I’m curious to see how you do it. Do you use the engine run time counter as week to be sure you are out of any cranking phase?
