BARO reads same as MAP when using external MAP sensor
I have a dedicated sensor to measure MAP and configured the internal sensor to measure BARO. The log shows BARO = MAP. I expected BARO to have a fixed value around 100 kPa. There is nothing physically connected to the built in pressure sensor on the EMU Black.
I’m running V3, client version 3.037 Exp. 1
Just to confirm, donyoubuse 3.039 version ?
The log chart shown above was made with 3.037
After your suggestion, I downloaded 3.039 client software. I will log BARO and MAP and post the results here.
This bug exists in all version. It will be fixed for 3.040
I see. Thanks for the quick response. Looking forward to 3.040.
I’m using Alpha-N fueling, but “Enable baro correction” is unchecked and table “Barometric corr.” is all zeros so I am not currently affected by this. I will enter settings for these after the 3.040 upgrade.
I’m still seeing BARO = MAP in 3.041
They don’t match exactly, but I would expect BARO to be steady near 100 since I’m using an external MAP sensor and reading atmospheric pressure with the internal sensor.
Magnified view:
Could you show me your MAP sensor settings ?
This bug was already fixed and works for sure in firmware 3.040 and newer
Is there anything wrong with my MAP, BARO parameters?
Is there another setting I need to fix?
Please upgrade firmware to 3.042 and test.
If it doesnt work then I will need your project, as your MAP sensor settings work for me correctly.
