High TPS rate causing false accel enrichment
Hi guys
What could cause a high TPS rate under idle condition and also “steady state” cruising condition. Values are from 5 to almoast 50 %/s.
I don’t think that my idle PID are to high, because the idle air% is only changing 0.5% and as said before the problem also occures under driving conditions.
U need to increase the filter strength for tps rate
Thank you for your help!
