Vr5 agz turbo lamda wbo heater
I have a problem with my lambda control. I’ve had this problem for a very long time and have never found the cause of my lambda fluctuations. This is now the third engine and several lambda sensors. When you look at the lambda sensor’s heater DC in the log, it jumps around wildly. What could be causing this? Several lambda sensors have already been used, and the problem persists with the third engine. The same phenomena occur with engines V2 and V3.
probelm.emublog (87.0 KB)
20260814_1811_59.emub (146.2 KB)
