Vw 9a self made trigger setup, rough idle!
Hello from estonia!
I ´m running vw 9a engine with emu classic, with 036103171B crank trigger wheel and 04C906433 sensor, the cam trigger tooth are selfmade on the edge of the cam and I´m using 04C 907 601 sensor for the cam, both hall sensors. By user defined setup I was able to get the sync to work but I´m not getting the round dot markings in the scope, and the car is running extremely rough and will work only with really advanced ignition.
I think there is no round dot on classic. Trigger looking good
Ok, thank you! the problem seem to be somwere else, engine only runs with touble the amount of fuel compared to the calculated value…
