Hi there
Does ecumaster work with this kind of trigger system?
shure. you have different options. you can run it as 4 finger or 1 finger input. just need to put on ground and voltage correct and you will get the signal for the cam on the middle out. i made it run on a 1.8 16v n/a engine and it works fine
