What Wattage 150k Ohm Resistor for LSU 4.9
What wattage 150k Ohm Resistor should be used for LSU 4.9 on EMU Black?
Im pretty sure that this only applied to the earlier versions of the emu black and the pnp harnesses being sold. I am pretty sure that the resistors are already installed from the factory if you recently purchased your emu black. That being said, here is the link that instructs you what to do.
Thanks for the response. I’ve already read that information, it doesn’t state the wattage, just 150k Ohm.
They are typically 1/4 watt resistors.
150kOhm at 12V are 0,00008Amps are 0,00096Watt = it completly doesnt matter what power rating resistor u use…there will never floe any relevant current through this resistor
Hello, I have Rev. F—do I need a resistor for that as well?
