I have a 1jz swapped e30 running a jzx100 harness with the pnp adapter to an emu classic. I want to just run my white analog wire off my AFR gauge to the software I have it wired to B5 (WBO Vs) I have no idea what to do in the program to set voltage or check if it’s even recognizing it. I know I can just wire it directly in I’d just rather run one wire and run it externally I just need it working for some remote tuning
If you want to use the analog output of the AEM, the O2 sensor settings should be set to ‘ExternalController’ and the input pin should be via AnalogIN.
Where am I selecting the input at though? I have it set to external but I don’t know how to select the input and make sure it’s workin before I crank
For V2, it’s Sensor setup > Oxygen Sensor.
