I have a quick question about how people are adding their wbo who are using the pnp adapters. Are you intercepting the wires in between the pnp and ecu or are you utilizing the stock 3rd o2 sensor wiring (if that’s even possible)?
thanks in advance!
thanks in advance!
Intercept the wiring between the ecu and PNP adapter.
The PNP adapter won’t use the wideband O2 controller pins, aside from 12V switched power. I usually splice that off the ECU’s power and run the other 5 wires direct into the ecu.
Sweet! Thanks for the info!
