I have an 02 is300, have an aem wideband wired into pin 2. I’ve noticed that the afr readings on the tuning software are reading completely different numbers compared to the aem wideband. Is there a way to change it? I’ve changed the analog input to pretty much all wideband files that come with the software and still can’t find the correct one. Thank you all in advance.
Probably ground on the gauge is not on the same as det3 hence the offset
Thank you, I’ll try that out! I do have the gauge grounded to the chassis as of now but I’ll change it and see
Found out I had to reverse the 0-5v reference to negative for the wideband input, works like it should now!
hi! i cant get that aem afr working at the software. what do u men by reversing the reference? can u maybe point me some of your wiring to aem gauge and to the det3?
Let me search for the diagram and I’ll send you the info
What do you mean with negative? Do you mean AFR at 0v=20AFR and AFR at 5v=10 AFR? My reading are not matching with that setting or if i flip it
