2 step set up rb25 vl commodore
just after some settings for 2 step, rb25 in a vl commodore. car is used for drag racing, manual car, wanting to build boost on the line,
I’m reasonably new to this and having a go myself, (qualified mechanic but limited experience in this stuff)
i was planning to run the aux signal wire to the hand brake light switch, is this ok?
chasing some settings for the 2 step too.
sorry if this has been covered before, i had a search but couldn’t find much, I’m new to here.
thanks, jake.
if you have a VSS sensor connected, you can set in the parameters that the lc is deactivated after a given speed, for example 5km/h, so you don’t have to think about it, everything is automated.
i do not have a vss sensor. i was just hoping to connect the aux input to the hand brake light, which would tell the ecu to activate launch control. i use hand brake on the line as its a manual,
i only have stepper motor aux’s left, which i assume wont be an issue to use as the light wont be on when ignition is off,
trying to figure out how to wire my fans to this now though as the way i have them currently theyre avalible with ignition off still
