2jzgte sequential turbo setup
I just installed the high flow twins in my Supra. My tuner says he can only get it to 5 lbs of boost. I also read where the emu black is t setup for sequential. Is it possible to set it up to where it can?
sequence_turbo.zip (12.0 KB)
I worked on a stock Toyota Supra with the OEM sequential turbochargers several years ago—around 2017 or 2018—so my recollection is somewhat limited.
At the time, I was able to control the turbochargers using the EMU Classic and parameter outputs. The AUX output was used to operate the exhaust and intake valves to manage boost air and exhaust gas flow, and the setup worked very well.
Since this was done quite a while ago, I don’t recall whether any modifications were made to the vacuum lines.
I’ve attached the EMU Classic file from that project for your reference. It may help you review how the system was configured.
Do you know how to get the tac to work? 94 Supra
