Hi guys
Since the 3.041 update I’m not seeing any data above 21.5 %tps and approx 5000 rpm, cells above all stay greyed out
01142946.BG3 (4.2 MB)
Looking back through the data this seems to not be working since I updated the edl-1 to the 1.17 firmware
The acc enrichment threshold for autoutne is 2%.
I will add for next build option to define this threshold. I would suggest for autotune change the acce enrichment threshold to make sure that small throttle movements will not add fuel.
I’ve just realised that the X axsi is from 0 to 20%.
It looks like a bug.
Could you post your project ?
Getting lots of rejection due to accel enrich so I’ve zeroed it out at low TPS rate, but being turbocharged and alpha-n the accel settings are proving very challenging, any tips would be welcome
If I disabled sample rejection all cells are filled so the reason is ACC enrich.
However I found 2 minor bugs ha ha. When you switch to ALphaN the X axis is from 0 to 20% by default.
The second if you change to AlphaN or Load alphaN project, the Autotune window X asis doesn’t refresh automatically, you need to close and open the window again.
