A3 8P DSG
Turbo gt3582
Injectors Bosch 630cc
Stock engine
Map sensor 3b
IAT
when I roll the car in drive mode without pressing the gas pedal, the car increases the revs by itself.
when I give it gas, the car revs up and holds them longer than it should after I let go of the gas
If you post your map and a representative log it will be quicker for us to troubleshoot your issue.
I have a very similar setup to yours (except 1000cc injectors) and don’t have this issue.
You can add them here. Just upload. It should allow you to attach them to a post
as a new member i cant post files have u any email or whatsapp, messanger
In the log it can be seen that the Idle valve increases its DC due to DSG DC correction, which causes the rpm increase:
Probably u should correct this table.
Second is throttle wire but first idk
ANDREI
11
Please make off fo MUX Switch, you have collision on Analog input 1
ANDREI
13
Mux switch enabled ON
Mux switch input CHANGE to None
Mux switch enabled OFF
This is for B31 failure right?
ANDREI
15
yes, i think you need make correct inpunts, maybe present collision in emublack soft…
check it in this week and we will see
