Im wondering on my pnp emublack when i press my clutch the idle jumps up to about 2k rpm. If i tap the gas it comes back down. I am brand new to stand alone amd running the ecumaster bfh start up map right now. Its a stock na motor. Any one have any insight to this? I can get a log if needed. Thanks!
First thoughts is that is an Aircon input mixed up with clutch ?
Maybe some IO testing can be done to check the inputs and assignments
I will check that out tis weekend. Thank you for the reply.
