3 cilinder engine configuration
Hi yall,
I have an engine with 3 cilinders (1kfre).now I’m getting bit confused.
Firing order is 1,3,2 and my injectors should are assigned as following: cilinder 1 - injector 1 | cilinder 2 - injector 2 | cilinder 3 - injections 3
Then firing order is
Cilinder 1
Cilinder 3
Cilinder 2
This is correct right?
And I can’t get my map to work (on board the ecu) and Afr reading is showing 14.6 constant (brand new Bosch 4.9)
