4 wire directional hall effect sensor wiring to WSStoCAN module
I am using SpecTec 0170QM-914 sensor (link), but its not clear to me how i should connect or configure the WSStoCAN ECU to interpret the velocity and directionality. the only Hall effect diagram in the manual has 3-wire senors. I have 4-wire. where should i connect the 4th wire?
The WheelSpeed module does not have inputs for direction information.
You have to leave that wire disconnected or connect it to a different module.
This is the first time I’ve seen a 4-wire sensor like that.
That is not a standard in automotive applications.
